** SAPPHIRE 290 VAPOR-X IN STOCK AT OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I believe we are the only stockist of this new worlds fastest 290 from Sapphire:-
Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) @ £379.99 inc VAT
Sapphires 290 Vapor-X is the fastest 290 on the market with a core clock of 1050MHz but even more impressive is the 5600MHz memory clock and with 4GB of RAM making this card perfect for 4K resolution and latest games such as Titanfall, Diablo 3 etc.
The Vapor-X cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950 <br />
- Stream Processors: 2560
- Core Speed: 1050MHz
- Memory Speed: 5600Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £379.99 inc VAT.
ORDER NOW
One very fast 290 and the cooler is fan bloody tastic! :)
We have not tested against Tri -X which was very strong.
All evidence points to yes.
As better power delivery and redesigned PCB.
Better than Tri-X?
The cooler has some design improvements along with a backing plate too, so cooling should be better and the Tri-X is one of the best coolers we tested for noise and performance.
PCB wise this has an improved PWM so should be a superb overclocking if your luck on the GPU lottery is good. :)
8 Pack/Gibbo bust one out of the packaging and overclock it please :D
I want to know what they clock like, also are there waterblocks available for these?
That cooler matches my system better than any other, can't say I buy for looks though when it comes to hardware since I have my custom loop, the cooler would be straight off :D
*cough* that 290 too heavy for you to bench for us 8pack *cough*
Looks is a matter of taste!! I think it looks great!!
That blue would be a hard colour to match though! Asus used to have some weird blues on their boards but most boards now are darker blue/brown/black/red/green/orange.
Seems you guys want me to test so I will. Tomorrow I have ASUS Matrix 290X air review to write. Then I will stick this in and see what its about.
