Fingers crossed I'll be getting my long overdue upgrade, which should be the following:
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x MSI Z87-G43 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard £92.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £53.99
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £49.99
Total : £376.56 (includes shipping : £8.00)
Having had a read through some threads it seems the H60 may not be my best option, as I do intend to overclock to at least 4GHz. The problem is I'm a bit limited with the cooler I can fit.
My Antec P193 seemed a great choice at the time, decent noise cancelling, with two top fans, one rear fan and a huge 200mm side panel fan (which intrudes into the case by about 10-15mm).
Is the H60 worth going for?
Would an H75 get me significantly lower temps?
Alternatively, are there any low-profile air coolers that would offer better cooling (maximum height can't be more than about 10-11cm), something like the Noctua NH-L12 CPU Cooler? My main concern is noise levels & cooling during the hot summer I hope we get, as my flat gets rather warm!
I'm also assuming my Thermaltake TR2 550W psu will be ok until I can afford a new one?
Edit: bugger...it seems the Noctua NH-L12 isn't socket 1150 compatible...
YOUR BASKET
