** Huge Savings - Performance Watercooling Radiator **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have a mental deal on this radiator.
I am currently using the AX series in my own system and they are incredible.
Easily the best looking and a great performer.
This radiator was £89.99 and we have a clearance deal of only £38.99 currently.
This is the best radiator you will get for the money without a doubt.
XSPC AX360 Triple Fan Radiator (Silver) @ £38.99 inc VAT
The AX is a new premium radiator from XSPC. The AX series combines a high performance copper/brass radiator core with a compact and beautifully finished aluminium enclosure.
The AX's core is a high performance evolution of the popular EX radiator series. The core includes advances from the EX series like welded seam tubes and splitter fins, but with a thicker core (21mm vs 16mm) and increased surface area.
The radiator core is fitted inside of a 3mm thick, extruded and machined aluminium shell. The screw holes are precision cut by CNC which eliminates misaligned screw holes and gives 3mm of screw thread. The aluminium shell also provides a perfectly flat surface to mount the fans against, which eliminates air gaps and any need for a gasket.
All of this comes together to make what we believe is the best PC radiator on the market.
- 3mm Thick Aluminium Frame (No aluminium in the flow path)
- Copper and Brass Core
- Paint Free Core
- Chrome Plated G1/4" Ports
- RoHS Compliant
- Dimensions: 128 x 40 x 406mm (WxDxH) (46mm at ports)
- Weight: ~1082g
- Screws: 6-32 UNC
- Fans: 1 x 120mm (2x with push/pull)
Supplied 30mm and 6mm 6-32 UNC screws
Note: The AX Silver has an unpainted core, which will oxidise over time.
Was £53.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Pity it's not a 420 or 280 :(
Could have been my first WC purchase at that price. Even if it's likely months before I start trying to get things set up.
If it is black... I will get it for my EATX build...
If it is 240... I will get it for my ITX build...
Pity that it is neither :(
its half price.
take it apart.
spray the shroud black.
spray the core black
reassemble.
this rad + can of spray paint = £45
black version of rad = £89.99
tempted to go and spray them all black and flog them at full price now :D
oh my god that's ridiculous!!! if it was the end of the month, I definitely would have jumped on it. dammit!
ERGMAGERD
This is amazing value. Normally at full price i say the premium isnt worth it because of the absolute gems that have cropped up in the lower price brackets recently but at this price...WOW
At the moment i have too many radiators. So many that i have run out of PC's and cases to mount them on. Still very tempted to get this.
What.A.Bargain!
we have limited stock at this price. we have around 20 left at this price point and some at a higher price.
in honesty, I am offering it at close to cost to get the stock moving
