- 11 Sep 2013
Silly me, didn't notice the 780 Lightning price was a This Week Only special...
So now my budget is up to £430 bracket.
I want the best performance for that price, preferably from a card that is (generally) quiet and easily cooled in a standard Corsair 500R case (ie, no water).
I also *promise* this is the last time I'll ever ask about or even mention this... until I next upgrade in a few years to a DDR9 card or whatever we're using by then!
I need something for 1080p gaming that will be OK in forthcoming games like Star Citizen, Elite, WatchDogs, The Division, etc and will run well with:
- FX6350 (OC to 4.5GHz)
- MSI 970A-G46
- 650W OCZ PSU
- 8GB 1866 MHz RAM (can always buy more)
I know that kit will hold the GPU back a bit, but I will be upgrading most of that lot well before I can afford a GPU upgrade.
I'm fairly set on a GTX780... but which one?
I've been pretty sold on the 780 Lightning, which apparently can overclock very high very nicely (perhaps to the level of a stock Titan, if I recall the reviews correctly?)... That part may be restricted by my Mobo/PSU though?
So it seems my choices are now:
YOUR BASKET
1 x Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra DHS Edition 3072MB GDDR5 PCI-Express Graphics Card £429.95
1 x MSI GeForce GTX 780 Lightning 3072MB GDDR5 PCI-Express Graphics Card £429.95
1 x Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card £419.99
1 x KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE** £419.99
Total : £1,709.47 (includes shipping : £8.00).
At this level, is it really a case of biggest numbers are best, or is there more behind it?
Or would I be better off with an AMD solution?
- MSI 970A-G46
- 650W OCZ PSU
YOUR BASKET
, And if i had the guts to try to get the non boosting bios working on mine it would probs go higher.
