If you dont use Prime as a main reason to use your PC dont use it to test its stability!!
No you should find out it isn't stable when it has corrupted your OS.
Ill get some screenies done after i finish work and put my daughter to bed.
I use linx,occt(linpack),prime95 and ibt. Ive always done it like this for true stability, also games don't stress your computer as much as the stability tests. I never crash in games apart from bf4 lol.
Well if your crashing in BF4 some things not right -->Stability.
OS who care!! Just image back easy.
Bf4 was working fine 3 months ago but since the latest patches i cannot even play....BF4 is full of bugs and i cannot even spawn. I have to Alt and Tab toto desktop to quit the game. No other game i have problems with except bf4, infact i dont even have it installed so its irrelevant.
The reason why i use all stability tests is because you run the risk of micro data corruption with each unstable hard crash or bsod. This is were SFC /scannow comes into play or even worse a fresh install of windows. This is why i use all tests as one test will find a weakness were another does not.
I have good watercooling as well, 3x RX360 rads, 2 D5 Pumps, best blocks that money can be. Everything i have is of the finest components, all in an M10 Caselabs case which ive had since 2011. Had it imported before most people over here even knew what caselabs were. When i bought my case, Jim used to operate out of Overclock.net and all purchases were done through forum PM. This was long before the Caselabs shop was even open. Anyhow im hapopy with it, i have a 900d also with 690 in it under custom water.
I would love to know if it's you that builds the overclocked systems for overclockers, I'll make sure I never buy one going by this comment, your saying it's ok to sell unstable systems.
A system that corrupts data and is unstable to me is faulty, and requires returning to be repaired.
Only unstable of you're planning on ruining p95 imo, I don't have time for it so never use it lol. I set my computers to clock for my uses, if it crashes dial it back or add more V.
ot of people will disagree. Oh well![]()
Another croc of **** argument about stability. Ffs, if its stable for what you use it for great, no need to sit on top of a p95 pedestal preaching to the rest of the community that if it doesn't pass xyz then it's not stable in your opinion. Nobody really gives a toss about that opinion tbh.
To OP, congrats on the nice chip, 911's do seem to fair quite well! Any idea what the lowest vcore for boot is? Tried on 125?
Robert
You are creating a dilemma for yourself.
Choosing which things to be stable at and what to ignore failure on.
Drawing back from the ragged edge to a point where your PC passes any test you set it would be better don't you think ?
Is that extra 100/200 Mhz really worth it when you know that you have instability running certain tasks ?
The difference between say 4.8 and 4.6 is not game changing and the benefit to you is peace of mind.
As it stands when you do run into problems running certain apps you cant be sure it isn't your OC rather than some iffy code that is the issue.
You're moving up the old rankings quickly
Nice going![]()
