http://www.overclockers.co.uk/showproduct.php?prodid=WC-104-MO&groupid=962&catid=2531&subcat=2537
Hi guys
I am thinking I may need to use some 90deg fittings going forward.
Does the item above come with everything one needs to use it? I believe with a std compression fitting you get a screw-in piece and the piece that is put on the hose and tightens to form the compression fitting - so two parts. I hope that makes sense
My question is if I buy these, so I need to buy another piece also?
Thanks
Hi guys
Thanks
