- 1 Jan 2012
- Scottish Borders - UK
I have my R9 290 under water and I've noticed it does idle quite hot.
I run dual monitors which I noticed also increases the temperature of the card.
BUT...
I'm sitting on the desktop now, not doing anything apart from browsing and I noticed that using GPU-Z the current clock speed is 1225 and the memory 1400. (These are what I've currently overclocked too).
Shouldn't the core be a lot lower when I'm not actually gaming? I'm sure I noticed it in the past decreasing and increasing.
GPU load is at 0%.
The card is idling at 53C under water.
I noticed something similar before I watercooled and on occasion it would be "idle" at 89C etc.
What's going on here then??
I'm new to AMD cards, is this the norm? Is there something keeping the core clock up as I'm sure it drops down? I know when I only had one monitor plugged in, the ram clock dropped down.
I've uninstalled CCC due to a conflict issue with Trixx, but I doubt this is a reason.
Any help appreciated!
BUT...
GPU load is at 0%.
