Anyone can overclock a computer, my 6 year old could, bump up the multiplier, if it cashes playing horrice goes sking, then ramp up the voltage.
It takes a pro to overclock a computer and make it prime / IBT / AIDA64 and 3D stable, it involves long hours of testing, tonnes of BSOD's, headaches, fine tweaking of voltages, memory timings and other tweaks, and of course beer.
My 4770k was the easiest CPU ive ever overclocked, took me just under a week to get it fully stable where it is now, its doing 4.6ghz @ 1.29v (happy to provide early proof for anyone who wants it) all under a custom water setup, TBH it was so easy, im bored now.
I agree with most of you, prime is not enough to test stability but in my books, its the best place to start, once your prime stable, then move onto the next test, the ones ive listed below are just 3 out of about 10 tests I run as well as every day use.
Ive had IBT crash after 50 passes
Ive had prime crash after 18 hours running.
Ive had mem test pick up errors at 6000%
Whats wrong with running these tests, if you not using your computer overnight then fire up a test and let it run overnight, providing your temps are ok of course, yes you may wake up to a BSOD, but then you tweak a bit more and run again the next night.
