Looks like it's full format time!
Caporegime
8 Sep 2006
On Ocuk
First time in over a year, possibly 2 or more! And all because of a retarded driver install that corrupted the operating system. I tried using system refresh as the system restore for some reason hadn't updated in a long time. Using system refresh was the worst mistake, it **** it all up, hangs basically everything.
Oh well :mad:
Restore updates itself so should have had many points to roil back to esp after installing a driver it should have made one.
What OS is this and was it a GPU driver? ;)
What ever happened restore didn't work and na, it was the latest PAX XFI driver :(
Anyhoo I'm on Windows 8.1 now and so far working fine, thank **** for back ups :D
Sometimes he releases untested flaky driver packages that he has even admitted he doesn't have the hardware or has tested.
I've had similar things in the past that I refuse to use his drivers because one time after installing I couldn't install the original latest available drivers from the manufacturer to go back on. People have to beta test for him most times.
Especially when he says " BEST SOUNDING DRIVERS !!! EXTRA TWEAKS " and then boom it tweaks the os not to boot anymore :p
Well he is right in a way, the noise floor is amazing with those drivers. Can't have noise if the OS won't boot ;)
That is not strictly true, the noise you make smashing the keyboard across the desk can sound nasty, although will be in surround sound :D
