Ah, I did wonder but I wasn't sure based on what your numbering meant.
No, your understanding of my post was correct, there's still a problem. But I'm not sure if this is normal, as the chain doesn't jump when you pedal the way which makes the wheel spin, it only jumps 1 tooth on the ring. Only when pedaling backwards (the way which doesn't make the wheel spin) the chain can drop on to lower gear (2nd from top).
