Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £17.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Only £17.99 inc VAT.
ORDER NOW
_____
MicroLab H21 2.0 Bluetooth Speakers @ £64.99 inc VAT
Wireless Bluetooth music entertainment; playback from any Bluetooth devices.
Amp
- Output power: 36 Watt
- Distribution: 18 Watt x 2 RMS
- Harmonic distortion: < 0.5 % 1 Watt 1kHz
- Frequency range: 50 Hz - 20 kHz
- Signal/Noise ratio: > 70 dB
- Separation: > 60 dB
Speakers
- Tweeter drive unit: 1”
- Rated power: 10 Watt, 4 ohm
- Woofer drive unit: 3.5”
- Rated power: 20 Watt, 8 ohm
Interfaces
- Input: 2RCA
- Output: Terminal binding post
Power
- Power supply: AC 100 V - 240 V, 50 / 60 Hz,
- Output - DC 18 V / 2 A
Dimensions
- Product dimension: Right - 116 x 198 x 202 mm (W x H x D), Left - 116 x 189 x 202 mm (W x H x D)
Only £64.99 inc VAT.
ORDER NOW
ORDER NOW
_____
Amp
Speakers
Interfaces
- Input: 2RCA
Power
Dimensions
ORDER NOW
