Caporegime
- 9 Nov 2009
- Planet Earth
AMD Pirate Islands Can be Announced The Summer
Source
http://extremespec.net/amd-pirate-islands-announced-summer/
Why would they kill off their current flagship cards inside a year with nothing on the market battering the 290's?
4GB min, maybe 5-6GB? It'll be interesting to see how well one of these would do at max settings on 4KNew cards... so soon...
Any ideas about what the VRAM will be on those 390s?
4GB min, maybe 5-6GB? It'll be interesting to see how well one of these would do at max settings on 4K![]()
Didn't NV do some shenanigans with the 660 where they had some 2GB and 3GB cards?With a 512Bit bus it will be 4 or 8.
I think its about time AMD did what Nvidia do, is 5.6 TeraFlops necessary on a gaming card?
The R9 390X looks like it would have about 9 TeraFlops of DP Compute, that's insane. AMD could cut half the compute performance out, save on a lot of power consumption and still end up with huge compute performance.
LINKThe colleagues over at WccfTech posted something about the next generation Radeon graphics cards. They dug up an old (what is claimed to be) roadmap which shows details about three GPUs, the R9 390X, R9 380X and R9 370X. There is no validation regarding the source material and their post is highly speculative. Then again .. rumors always start somewhere and props to them for retrieving that info.
Now in their news item posted they already claim themselves that all information is to be taken with a pinch of salt, which really is the proper way to address this information.
The source leak indicates future Pirate Islands GPU code names and some specs. Specs NEVER are final which makes me frown up-on the posted material, anyway here's what they are claiming:
According to these details all GPUs will be based on the TSMC 20nm Node and will be true Pirate Island cores, which is why nomenclature of the dies will be derivative in nature. Another thing mentioned is that all Pirate Island GPUs will have the DirectX 12 Hardware Feature Set. According to these details the R9 370X is slated for announcement/arrival sometime this July-August this year. The R9 370X will feature a ‘Treasure Island XTX’ core and supposedly has 1536 Stream-processors, 96 Texture Units and 48 ROPs on the uncut die. Of course this road-map precedes the report we got of TSMC having a little trouble with 20nm so I am not sure how valid the time frame is anymore.
Now according to the details, we will see the R9 390X before the R9 380X. The R9 390X will feature the ‘Bermuda XTX’ core and feature a staggeringly high number of SPs, ie. 4224. The Texture Unit count is 264 with 96 ROPs. It is slated to show up late 2014 around November or so. Once again keep in mind the TSMC comment above. Finally the R9 380X which will feature the ‘Fiji XTX’ core and the following die configuration: 3072 SPs, 192 Texture Units and 72 ROPs and should appear sometime early 2015. Now interestingly the R9 390X ‘Bermuda XTX’ GPU is slated to have 512 Bits of Memory Bandwidth while as the R9 380X is slated to have 384 Bits with the R9 370X coming last with 256 Bits. Now the road-map even hints at the clock speeds of AMD’s future GPUs but I think it is prudent to mention that all these tech specs at this point in time are about as solid as the wind. However let us continue, with the help of this table:
GPU Codename Core Stream Processors* Texture Units* ROPs* Core Clock* Memory Clock* Memory Bandwidth*
R9 370X Treasure Island Treasure Island XTX 1536 96 48 ~900Mhz ~5Ghz 256Bit
R9 380X Fiji Fiji XTX 3072 192 72 ~900Mhz ~6Ghz 384Bit
R9 390X Bermuda Bermuda XTX 4224 264 96 ~1000Mhz ~7Ghz 512Bit
* Values are not indicative of the final product.
If AMD released a 20nm chip this year and Nvidia wait for that to be released, they'd only get their 20nm chip out a couple years later, no one reacts to the other guy in silicon you do your own thing, make a good chip and hope it's better or relatively close to what someone else makes.
You make a good point. I wouldn't be the first to suggest though that Nvidia and AMD seem to always be on exactly the same page, often nearly-simultaneously releasing products at the same performance and price levels. I wonder how much they're really "doing their own thing".
