Titanfall (XB1/360)
The Xbone version drops to 30-40fps regualarly, didn't all the Xbox fans say that a steady 30fps is better in the Tomb Raider thread or did I just dream that?
I'd say the Xbox One version regularly dips much lower that that, often into the teens when it's really busy. And the screen tearing is appalling. I love TF but it shows up the Xbox One's limitations at the moment.
I don't think it shows anything of the sort, as less power as the XO has, its still capable of a lot more than that, its more a case of they have could the ceiling on the Source engine they used to make it.
A steady framerate would off course be better than judder when frames drop, which is why infamous is getting a patch that let's it be fixed to 30fps on the PS4.
The answer always seems to depend on whether you are comparing Xbone to PS4 or Xbone to 360.
Xbone to PS4 it's about gameplay man, 30fps solid is better, no one is looking at textures we are too busy enjoying the game.
Xbone to 360 ew lack of detail on that rock over there. Hitting 60fps once per week is so much better than 30fps aghhh my eyes!
:p;)
You forgot the bit where if you want graphics you really should own a PC and not bother with a console - always enjoy that one :p
I think thats unfair, it shows more how poor a dev Respawn is, might be able to design a good game but seem to be found wanting when it comes to deving one...
ps3ud0 :cool:
Regardless of whether it's a problem with the engine, an issue with not enough optimisation, whether it was coded originally for the 360 and then ported to the One, that the devs haven't got their heads around esram or whatever, or that the hardware simply isn't up to it, the end result is the same - low frame rates, tearing and an experience which shows up the xbox one at the moment. I think things will improve (probably dramatically) but it's hardly impressive as it stands.
They're patching it to 5 soon thank god. If I'm still playing that'l be a godsend! :)
Yeah I saw that last week, apparently there is a little something for those who have completed it in it's current form which I wanted to secure.
Competing against 5 downloading housemates on a 6mb connection made it an absolute head sore! :(
Yeah I don't fancy it and wouldn't play enough to attempt it anyhow! Am only at end of Gen 2. I think I have 7 Goosers total. Hope they give you something good for the effort! :)
Good going! I've got a total of 3 and I'm at level 45 Gen 5 :( I would like to get the 50 before the cap lower, but it just isn't going to happen :( Any tips?
I hit level 50 in 38 games, but didn't complete gen 5 challenges until hitting 97 games :(
My tips would be;
- Chain gun w/ extended magazine
- Don't chase the titankills but concentrate on them pilots ejecting out
- Try and get in a position where the sun is behind you, trying to goose pilots whilst they're in the sunlight is a nightmare!
- Don't get right underneath them when they are ejecting, try and get a good bit of distance so you've an easier angle to work with
- Be prepared to endure the long grind, some games you might get 3/4, then for 5 games not get any. It just takes time!
Hope this helps :p
My tips would be;
Hope this helps :p
Heh, thanks... I've level 50 now, and have a mighty 4 gooser kills (9 ever). I'm just going to admit I'm **** at this. Pilots just seem invincible in the air for me :( My ping is generally 40+, I wonder if that has anything to do with it (desperately looks to assign blame to anything else).
You'll get a lot better at it.
I was competing with 100-200ms pings at the best of times to the Western EU servers and still managed (eventually).
Gen6 has the brain surgeon challenge, that'll be fun :p
If you rodeo a titan to destruction you get thrown into the air with the other pilot, they should be just below you in the air = fairly easy kill. The hard part is the rodeoing and hoping the enemy doesn bail and kill you first.
The patch should be out alter today to make it 5 goosers anyhow, plus private matches etc,..
Patch notes: http://www.totalxbox.com/74900/titanfall-xbox-one-update-out-today-full-patch-notes-here/
Erm, anyone else just stuck with "no servers found" after the patch?
Ahhhh, yep. Sounds like the patch has broken the live servers. Superb.
