Looks nice.
For ssd cover, you can use some white acrylic. Just go to plasticshop.co.uk and type in the size, thickness and color you want in the calculator. They have good prices and are quick on delivery.
looking good.![]()
Nice work on the acrylic!
Maybe adding some LEDs will be nice
Nice build
I need to say this before you even consider filling your rig with liquid... You have your connections on your pump WRONG! DO NOT RUN IT THIS WAY! the hole in the centre of your pump top is the inlet and should be fed from your reservoir. This is extremely important. Apart from that, looking fantastic! Might want to consider making a new front panel or modding the existing one to allow for better airflow. My gpu temps decrease by 20 degrees when I pop off that front cover (full loaf).
^ damn, give that man a medal.
Yeah, especially with the rad first, you're likely to have priming issues.
swap them round
Also, give that rig one hell of a tilt around, it can take it! That top rad will only let go of the air when you rock it quite far forwards (keeping front feet on the ground) hoping for no leaks!
