Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Having changed from the Z87-A which was a good board in it's own right, to the Hero i have been having problems with overclocking so if any Hero owners could help it would be much appreciated.
First off i couldn't get any overclock to work without a 0124 bsod even with increasing voltage. Just to try something different i tried the cpu level up at 4.4ghz and it booted fine. I ran linx for 20 passes and max voltage was 1.264v which is exactly what the 4670k needed for 4.4ghz manually in the Z87-A. I then tried manually and got the same clockspeed with the same volts. Unfortunately it doesn't lower the volts at idle so i tried the offset. I applied 0.030v which gave me 1.254v when loaded. Unfortunately the same thing happens as it did on the Z87-A, after around a minute the voltage shoots up to 1.360v and along with it the temps!! This is doing my head in now and i really would like to get this sorted once and for all. How do i stop this happening while still having a stable overclock and still able to lower the voltage at idle?
I am on the latest bios, with all the latest drivers, fresh install of win7 pro, balanced power saving in windows. LLC has been lowered to lvl 3 for now.
