The Witcher 3 - GTX780Ti Pushes 35-45fps At Max?
According to Gametech, The Witcher 3: Wild Hunt is a very demanding title; a title that a single GTX 780Ti struggles to run when higher levels of AA are enabled. As the Russian gaming website noted, the PC version runs currently with all its bells and whistles enabled (plus 8xMSAA) with 35-45fps on a GTX 780Ti at 1080p. Naturally, a single 780Ti is able to hit the 60fps sweet spot in its current form provided MSAA is lowered.
Moreover, it is said that the PS4 version will run at 900p/30fps while the Xbox One version will run at 720p/30fps. What's also interesting is that the console versions of the game will meet the minimum graphics settings of the PC version. Gametech claimed that The Witcher 3 on consoles will look similar to The Witcher 2.
http://www.ggmania.com/?smsid=the-witcher-3-gtx780ti-pushes-35-45fps-at-max-37014
All I can say if you are an AMD hardcore Witcher gamer, then if you want ALL the bells and whistles, and finish the trilogy in it's full glory, then sell up and get a 880ti/Titan 2/(SLi
Featuring Gameworks/PhysX, I'm hoping the figures quoted are true that the 780ti can only push 45fps max(on the provision that the 780ti drivers are fully optimised for W3@launch) on hoping that it's truly pushing the capabilities of the PC to it's full potential.
Then hopefully more devs take the same approach and push the PC instead of equalling console ports.
