how to work out my mpg?
12 May 2011
Southampton
How can I work out my mpg in an old car which doesn't have a mpg-o-meter?
Yes I know I can see how far I go on one tank and use my tank size to work out fuel per mile etc etc but I don't completely completely drain my tank, I overfill my tank and my tank probably has 19 years of crap resting in the bottom of it. Also my fuel gauge readings are rather unhelpfully not equally spaced- 3/4 full is more like 13/16 and a quarter full is more like 1/5
Anyone got any tips?
Fill car up at petrol station till the first click
Reset trip metre
Drive till fuel light comes on (or until fairly empty)
Fill up till the first click taking note of the litres used
Note down the miles you've covered from your trip metre
Put the distance you covered & the litres used into here http://www.mpg-calculator.co.uk/
You can use a website like Fuelly.com as i do so you can track a long term average as that takes some of the unpredictability out of a 'bad' fuel up where it clicks off early for example http://www.fuelly.com/driver/sovietspybob/yaris
when empty fill up, look at pump and note litres and reset trip.
when empty put miles and litres into mpg calculator.
repeat get an average.
Have you worked out what volume the tank can hold now? Tanks shrink with age, so any calculations you do now will be inaccurate :(
Surely the tank size is actually irrelevant to mpg calculations?
It's simply the miles driven for the fuel used, so as long as the tank is full at fill ups, it's simply the litres put in and the miles between fill ups? How big the tank is only determines how much you can squeeze in, and is unlikely to change very much at all between fill ups every 250 - 650 miles.
:confused:
Should I be checking the straps on this regularly if it's going to shrink?
Wow clearly my comment went over people's head!
Yeah it is, generally for cars you'll know the tank capacity so you just see how much miles you've travelled to a tank. Or you can use how much you've filled off the petrol station receipt, and perform the same calculations as fuelly.
