I am currently using a 570 GTX SC and it is struggling with my new 1440p monitor. I want to play BF4 with max comfort and I recently came in possession of Titan Fall so I guess it's time to upgrade!
My current specs of any valued worth are:
CPU: 2500k i5
MEMORY: 8GB Corsair XMS DDR3
PSU: Corsair HX850W
Motherboard: Asus P8P67 Pro
Currently I have my focus set on a Gigabyte GTX 780 1GHz Windforce.
My one concern is when I go to upgrade to SLI in about 6-12 months time that the positioning of PCI-E on my motherboard (practically hugging eachother) will cause problems.
So...
Regardless of budget in mind, what do the lurkers of /gfx recommend I do? Money isn't a restriction at the minute, although I feel reluctant to spend more than £800 (total for sli) on something that will lose it's value and need upgrading in about 3 years.
The current plan was to get a Windforce GHz 1 now, then get another + new CPU/MEMORY/PSU and a motherboard with better PCI-E positioning in the future.
CPU: 2500k i5
PSU: Corsair HX850W
So...
