Please don't shout at me... But... eBay? I have 225/50/17 all round on my Astra, £100 a tyre, or can get a pair of 225/45/17 for £77.50so just waiting for those to be delivered..
Part worn, I presume?
Got my tyres earlier this week, went to take another look at the old ones and noticed I was misreading my depth indicator
Instead of mostly around 2.4mm they're more like 4mm, so the dilemma - to change or not to change?
Storage for the four new tyres isn't much of an issue at the moment..
Funkytyres were very competitive when I used them.
Either wait till they're down at a couple of mm or ask the garage to give you them back and fire on eBay. If new ones are circa £120 some mug will give you £40 a tyre @ 4mm
Ive found its no longer cheap to buy on camskill et al and get them fitted as nobody will fit them for the 5/ corner any more around these ere parts. Unless you know otherwise (Wilts)..?
