Higher res will make a difference i suppose. At a rough estimate a 2500k would be about 200mhz ono slower than a 3570k and 3770k which i had. Ive found the 4770k to be around the same faster again than the ib chips. Memory wont make any difference as ive used 1600mhz stuff in this current setup and ran the ram in sig at both 2400 and 2600mhz.
Resolution plays a big part, If I'd put the scaling to approx 115% the gpu usage would be hitting 98% on both cards
