Getting Best Deal from Audi
I find the ride quality on our A6 S-Line with 20" alloys fine TBH.
Read the agreement - you may find it's better to keep the finance for a month or so after the 14 days cooling off and then settle the finance with the loan as opposed to cancelling it.
[TW]Fox;26152484 said:
It's not the 140 is it? Thought the 177 had an exhaust each side?
The 2.0 177 has twin exhaust outlets on the left. \Its the 3.0 that has a single outlet on both sides.
Can you even get the A6 in the 143?
That must be feel pretty lethargic if you can.
Even with 245hp my F10 doesn't feel that quick.
You can't, just had a look and the engine options start at the 177 2.0...the only petrol now is the 245 hybrid TFSI.
My 177 A6 doesn't feel lethargic or slow, I have the manual though if that makes any difference. Mind you it doesn't feel like a BTCC either. :p
The one I bought seemed pretty quick to me. However that is compared to a Toyota Corolla 1.6 TSpirit (2005) and Mercedes E270 (1997).
Mine is ok as well, I came from a Range Rover Sport. It feels quick enough and doesn't feel underpowered at all, which is the important bit. In fact it doesn't feel all that different than my old ST220 tbh.
