750D Fans
18 Feb 2013
Birmingham
i have;
x2 intake 140's in the front
x1 140 exhaust in the back
A corsair h100 in a push pull config up top as a intake
is this the best fan orientation i can use in my case?
from what the OP seems to say in my mind is having all the fans as intakes but only the rear fan as an exhaust :confused:
Nope looks like your right and we read it wrong.
Then the answer is No its a bad setup as it dumps all the prcoessors waste heat back into your case and a single 140 wont remove it.
2 Possible ways in my opinion.
Most common with the fronts being intakes, the lone rear as an intake and the roof/top fans ax exhaust fans. (basically curved bottom to top)
or with the 750d since the front panel is restrictive.. having less than 20mm gap either side to push/pull air, i'd probably have the top and rear fan as an intake, and the front fans to exhaust the air. (inverted curve)
thanks for the advise guys, i thought about front 2 intake, rear intake (ill have to buy a 140mm dust filter) also and the h100 in push pull as an exhaust.
Wouldnt that be pushing the hot air from inside the case through the rad causing the cpu temp to climb?
no matter which configuration you decide, there will always be hot air moving in a particular direction, but as you should know, hot air rises.
To be honest, i doubt there would be much of a climb in cpu temp.. probably a degree difference if that, i guess its just a case of how fast your fans can dissipate the heat
:) well i have a AF140 in the back, 2 standard corsair 140s in the front, 2 standard 120s and 2 SP120s on my h100
