is arctic silver 5 good for GPU TIM?
Gelid GC Extreme is my thermal compund of choice just now. Have gotten good temps on my cpu and both my gpu's using the stuff. Found it quite difficult to spread though. Other than the liquid metal stuff though, GC Extreme seems to come out on top, or near enough on top of all the comparisons.
The fact that it's hard to spread makes a very good comment to be honest, with the more "movement" GPUs tend to get over CPU HS/F's a more.. gelatinious TIM might be an idea worth thinking about.
God a tube of AC5 lying around somewhere for my current build, bought it then found out my cooler had it pre applied, Temps are a little higher than what they used to be, so it's due a change soon.
Awesome! Thanks for all the feedback guys, appreciate it. I only asked because Ive ordered AS5 for my CPU's, and wondered whether i can use the same.. but at £8.99 I think I might get some MX4 for my GPU.. Its not like I'm replacing TIM daily so worth the small investment for the better results ;)
Any advice on spreading techniques for GPU? Ive always spread TIM via card method but found this youtube video which makes me think its not actually the best method. From watching the video I would say X method looks better i.e. no bubbles/pockets of air but the example is for a CPU so not sure if it applys to GPU. The only issue i see with those techniques is the whole CPU/GPU isn't completely covered.. surely with TIM not between the heat sink and GPU, heat wont transfer as well?.
And correct me if i'm wrong but isn't the amount suppose to be barely visible, i.e. semi transparent when applying TIM I.e Less is more?
Cheers Again Guys!
