Right, I'm trying to put together an OK PC for a friend who's 14, and hasn't enough cash for a full PC. He doesn't know anything about PC hardware, but what I've got so far is this:
Intel Core2 Duo 3.0Ghz CPU
Intel DQ45CB Motherboard
4Gb DDR2 RAM
250Gb SATA HDD
350W PSU
Problem is, I'm aware that there's a "generation jump" between earlier PCI-Express cards, and PCI-E 2.0
It looks like this board supports PCI-E 2.0, but I'm not quite sure where to aim in terms of what graphics card to put with this. (2nd hand of course)
Maximum budget is probably going to be around £50, but for that I seem to be able to find a GTX460 as about the best bang-per-buck, but would that be overkill for the rest of the system spec, and also possibly drawing too much power?
I'd be fairly confident in sticking an old 8800GT in, or a 9800GT (same thing I know) but they seem to have acquired some kind of legendary status 2nd hand, and sell for WAY too much money.
Anyone got anything else that they can suggest or recommend? I'm familiar with the nvidia 'generations' better than ATi, but I'm just hoping to find something that isn't overkill for the rest of the spec.
Cheers
4Gb DDR2 RAM
250Gb SATA HDD
350W PSU
Cheers
