Radeon R9 290X decimates previous records in HWBOT Unique Heaven
Caporegime
12 Jul 2007
United Kingdom
1540Mhz on the core? :eek:
It seems to be a good week for overclocking this week. Overclocking enthusiasts seem to be in the mood with new records being set every day. This time, their target has been the AMD Radeon R9 290X. Slovenian enthusiast Moonman has set new records for the card in HWBOT Unique Heaven with a score of 5504.9 points on the DX11 extreme profile. This translates into the global rank of 1 out of 1000 for single core GPUs and a rank of 1 out of 82 for the R9 290X.
Sources
http://wccftech.com/extreme-overclocking-radeon-r9-290x-sets-records-hwbot-unique-heaven/
http://hwbot.org/benchmark/unigine_heaven_-_xtreme_preset/rankings?cores=1#start=0#interval=20
What I dont get is how an amd card has the world record on the extreme preset. Is this using a different heaven to what we use here. I suppose it has to be as heaven is on version 4 here and the scores are way lower.
Yeah its using the older version of Heaven i believe.
The HWbot benchmark version of Unigine Heaven is based on the old 1.0 version... so it's really not contemporary nor does it push the GPU as hard as the 4.0 version.
HWBot really should look at updating the software they use as some of the results they get now are rather pointless.
A good example is the OP in this thread - running the CPU on LN2 to get a result on a single card in an old version of Heaven. If you are benching a GPU it should not turn into a contest to see who can overclock the CPU the highest on LN2. Just use the lastest version of Heaven and LN2 is not needed for the CPU.
Outdated or not, i think the clock is worth any praise going that way.
Would love to see its performance on benchmarks i actually use though, because 1540 on core is just a big number to me without other things to compare!
Add ~50% to stock clock 290x scores should give a rough indication :)
Having said that, my 290x has scored lower than many other 290xs with the same CPU at the same or lower clock in some of the benchmarks.
eg. with my 4770k at 4.5 and the 290x at 1281/1580 i score around 3060 in Valley but there are people getting a fair bit higher with less or roughly the same clocks.
Always though that some chips can score a fair bit better than other at the same clocks. Maybe my clock is just unstable but not producing artifacts for me to notice and so is just scoring less due to errors.
+1
This is my point, the guy has done well to get the GPU running at that speed but it would be nice if HWBot used up to date benches that people can relate to.
Valley is not a good bench to test with as it is all about CPU speed unless you run it at 1600p or higher. It bottlenecks my Titans so bad that i score near enough the same at 1080p and 1600p with them.
