Hi there
OK you won't see a promotion like this anywhere else, I found these in a corner of the warehouse and I thought of the perfect excuse that you guys can use with the Mrs. When she complains you spent £400 on a graphics card, just say but yeah I got the kid a games console so I am not so selfish.
SEGA MegaDrive Retro Games Console - Retail @ £29.99 inc VAT
Have a blast from the past with this retro console designed by SEGA pre-loaded with some of the very best classic arcade games. Have hours of fun with this great console at the price of a modern day PC game.
The following games are included pre-loaded:-
Streets of RAGE
Streets of RAGE II
Chakan
Gain Ground
Golden Axe
Columns III
Columns
Golden Axe III
Sonic 3D Blast
VIRTUA Fighter 2
Sonic Spinball
Alex Kidd
Altered beast
AND MANY MORE!!
The unit is SD card expandable (SD card not included) and comes with both UK/Euro adapters so it will work in both the UK and Europe. Connects to TV's via RCA connectors, so white/red audio RCA's and yellow video RCA connector.
Only £29.99 inc VAT - FREE WITH THIS CARD
ORDER NOW
EVGA GeForce GTX 780 Classified "Dual BIOS" 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3788-KR) @ £407.99 inc VAT
EVGA Classified is one of the most overclockable 780's on the market with a very advanced and highly uprated PWM to handle higher voltages resulting in better overclocking potential. Of course this card is epic for gamers as well having no issues with the latest games such as Titanfall, Thief and Diablo 3.
EVGA is also introducing a brand new cooling design; the redefining EVGA ACX Cooler. With a 40% increase in heatsink volume, the EVGA ACX is more efficient at dissipating heat, allowing for 15% lower GPU temperatures. A reinforcement baseplate maintains a straight PCB, and helps lower mosfet temperatures by 7% and memory by 15%.
Even the fan blades are of the highest quality; with a 700% increase in strength, and 25% lower weight when compared to competitors. This makes the fans 20% more efficient by requiring lower power levels. EVGA is also using double ball bearing fans which offer a 12 year lifespan, 4X longer when compared to competitors!
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Dual BIOS
- GPU: GeForce GTX 780
- Core Base Clock: 993 MHz
- Core Boost Clock: 1046 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£429.95] Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
Streets of RAGE
Streets of RAGE II
Chakan
Gain Ground
Golden Axe
Columns III
Columns
Golden Axe III
Sonic 3D Blast
VIRTUA Fighter 2
Sonic Spinball
Alex Kidd
Altered beast
AND MANY MORE!!
ORDER NOW
Features:-
Specification:-
- Dual BIOS
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
