Hi guys,
As the title says, i'm getting fed up with endless problems with the h80i, i'm on my 3rd one now and the latest issue is lack of fan control via link and an increase in cpu usage causes the fans to max out - temps are always fine (38 - mid 50s under load )- done the usual reset/firmware/software updates/different fans - enough is enough.
I use a 600t case / budget isn't a problem / doesnt need to look pretty or have flashing lights / needs to be quiet as I work from home quite often and can't have it sound like a helicopter is taking off next to me.
Thanks for your help.
