Hi there
If you want the worlds most powerful graphics card and also one of the quietest and coolest too, then look no further:-
Asus AMD Radeon 295 X2 Dual GPU 8192MB GDDR5 PCI-Express Graphics Card @ £1,199.99 inc VAT
The ASUS R9 295X2 is a brand-new high-performance graphics card powered by dual AMD Radeon™ R9 series graphics-processing units (GPUs) and equipped with a highly-efficient, hybrid liquid and air-cooling system.
Fitted with 8GB of super-fast GDDR5 video memory, R9 295X2 exclusively benefits from GPU Tweak - the real-time tuning tool that's available only to ASUS customers.
R9 295X2 delivers fantastically high performance straight from the box but only ASUS customers are able to push the dual GPUs to the very limits with GPU Tweak, our exclusive real-time tweaking utility. This easy-to-use tool grants intuitive and instant control over both R9 GPUs, video-memory clock speeds, voltage levels, cooling-fan speeds and power targets, so ASUS customers are able to overclock R9 295X2 easily and with high confidence.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time - so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
The new ASUS R9 295X2 graphics card is fitted with dual R9 series GPUs running at 1018MHz, ensuring that gameplay is fast, smooth and free from stutter - even when running at the latest 4K/UHD (ultra-high-definition) resolutions of up to 2560 x 1600 pixels.
Gamers can also connect up to six displays , enabling players to spread their battlefields across a vast expanse of screen real estate to create experiences that are truly immersive.
ASUS R9 295X2 is engineered with a hybrid liquid / air cooling system. The tidy and highly-efficient design requires no assembly and works from the moment the two-slot card is inserted, so no setup is required.
The active fan, with underlying radiator to dissipate heat from the liquid-cooling pipework, fits standard 120mm mounts, so installation couldn't be simpler. This clever hybrid liquid and air-cooling system provides exceptionally efficient cooling for both GPUs and the card's memory chips and regulators. Dedicated liquid cooling for the dual R9 series GPUs is supported by a high-efficiency fan that dissipates heat from other critical components, reducing overall operating temperatures and increasing stability - ensuring that R9 295X2 stays chilled, even when the on-screen action heats up.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 3yr
Only £1,199.99 inc VAT.
ORDER NOW
Gigabyte AMD Radeon 295 X2 Dual GPU 8192MB GDDR5 PCI-Express Graphics Card @ £1,139.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
Only £1,139.99 inc VAT.
ORDER NOW
MSI Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £1,139.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
PowerColor AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £1,099.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
Only £1,099.99 inc VAT.
ORDER NOW
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £1,099.99 inc VAT
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
Absolutely amazing cards, especially in Crossfire with 4 GPU's!!!
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
