Shame because Rockstar should at least show off Agent.
On the GTA V topic I think Rockstar would be silly not to release it on the next gen consoles but I think it will only end up with a PC port tbh.
Thanks for the replies guys.
I think I'm going to hold on till E3 to see if they announce something. That would be 10th to 12th of June. If there's nothing by then, I reckon it will have to be a PS3, just because the online service is free really.
EDIT: Having said that, if you look at the list of exhibitors for E3, Rockstar aren't actually there...so the 'news' that suggested they'd announce it at E3 might be more speculation/made-up-crap. (http://e314.mapyourshow.com/5_0/exhibitor_results.cfm?type=alpha&alpha=R)
This.Don't bother, it's not that great anyway...
isn't the PS4 similar to a modern PC anyway?
surely it would be simple to port the PC version over to PS4?
Presume the ps3 performance issues on the digital version have been fixed? If not then make sure you get a physical copy.
Assuming they release a PC version.
Either way, you'd be silly to pay £50 for it.
Personally I'd go PS3 because One Disc, online is free and you get a BluRay player however you won't be able to do HDMI > DVI because of HDCP (or whatever it is) unless you get a DVI adapter that's HDCP Compliant.
