It's better with friends to race against, not sure who it was here but I logged in and saw they had beaten all my times on the Artic Open and I managed to get most of the records back![]()
Lol really , really really... I think you need to go read a little more... Erm nope is the answer. ps4 has smoother fps, less visable tearing if any and a higher res then the x1.
I only reply to put your trolling to rights... Good bye ...
Yep, you've got work to do![]()
Wow really, I seen some screen tearing and texture pop on XB1, which you said is also there on PS4. So like I said sounds the same on both consoles. I like how you mention PS4 has tearing then try and change it to less visible tearing if any LOL.
Blah blah blah, you still there, you've done nothing but rag on about this and that... x1 has terrible screen tearing, ps4 its been noticed occasionally huge difference... Please do us all a favour and go back under your bridge..
If you can't accept both versions have similar issues then there is no need to go into a meltdown.Aaaarrrgggghhh I can't bunny hop for ****.
Got a faultless run on Cold Storage. Pretty happyShame about the few seconds I lost near the end, ah well.
You was so close to losing it at around 32 seconds![]()
the harder levels are just that - hard. I can't do the bunny hop, so that pretty much means I can't progress on the harder levels, as bunny hopping seems to be pretty important, after nearing a 100 faults on one level I've now quit - wish there was an area practice.. although I guess you can do the training over and over again, which i've tried and it hasn't helped.. : - )
