780 to 780ti
6 Jan 2004
leicester
As title have any of you gone from a 780 to a 780ti if so was it worth it. From a lot of the benchmarks it looks like maybe 20fps more in a lot of games if so did you see them fps jumps
Yes its faster but IMO I would not upgrade from a 780 to a 780Ti unless you need more VRam and wait on the 780Ti 6GB so you would gain faster Core+VRam.
What is your CPU (I though it was the Intel C2D till I seen Mobo is AMD Chipset).
im asking on behalf of someone else my cpu is a fx 6300 not the fastest chip in the world but does a good job lol
I stepped up from a 780 Classified to a 780 Ti and the performance increase is pretty decent, though I doubt you will notice it unless you look at your fps all the time.
The 780 to 780 Ti upgrade is small and not worth it man. How about another 780 for sli if you wanna spend that kinda money.
Decent clock 780 to decent clock 780ti is usually around 10% performance difference - wouldn't rush to it myself though can be useful for playing above 1920x1080.
With respect if your planning on doing that with the CPU in your signature? then more often than not the performance increase you will get is 0!
What games do you play?
When gaming I have enough trouble figuring out if I am using 1 or more cards as visually the difference is often non existent, going from a fast card to a slightly faster card is going to make practically no difference at all.
Keep the GTX 780
Keep the GTX 780
^^ This.
Keep the GTX 780
A real man notices the difference Kaap... because of his overlay. :D
I took a (reference clock) 780ti out of my system and stuck a 780 in and can't tell the difference......... possibly due to the GHZ edition boosting to stock 780ti performance :P
Roff I know you love to justify your hardware but a Ti can also be clocked.
A Ti is faster than non Ti, stock or clocked.
I take it your new around here :P
On a serious note my 780 GHZ at its out the box boost will match reference clocked 780tis in benchmarks, obviously you can clock a 780ti up to performance that a non-ti can't reach through over clocking but thats another story.
Lurked a very long time, long enough to know you love your hardware and always go on about the super duper golden sample you have with all previous GPU's also. ;)
Cannot really compare clock differences on OC models and vendors vary it, clock for clock is where it really is for example a 780 vs Ti at same clocks but at end of the day the final OC does count as that is what you will be gaming with and getting the end FPS with.
Look at the benches here.
Yeah them golden sample cards :D http://aten-hosted.com/images/GPUZ.jpg (actual stable clocks).
Not talking clock for clock obviously a 1GHZ 780ti will beat a 1GHz 780 just saying that my out the box 780 GHZ clocks will match in benchmarks FPS for FPS a reference clock 780ti which is quite nice.
(PS My 780 GHZ isn't _that_ special its a nice out the box boost for a 780 but 1 in 3 GHZ edition apparently hit the same 1188 boost clock).
I went from a Titan to a 780 Lightning then back to a Titan (RMA Replacement) then 780Ti Classy, i only really done it to be able to have a new toy to bench.
I would say no, it's not worth it.
Often but not always its just E-Peen, A few extra FPS on top of 100 will make no difference, if your pushing maxed out Crysis 3 settings ~10% will make little to no difference to 40 FPS.
The <£100> extra cost between the 'Second Fastest' and 'Fastest' is really just so you can say "I have a 780TI or 290X"
