It's a slightly upgraded version of the 199 as Dsteviedee has pointed out, yet costs a fair bit more. If your willing to up your budget then I'd be inclined to get an RX-V375 and then a speaker set of some sort, depends how much you want to spend really - you don't really need to limit yourself to Yamaha amps either, Onkyo, Denon, Sony and Pioneer do all have decent entry level offerings, it's just that the Yamaha 199 one is particularly good value. Peter Tyson seems to be recommended quite often and they do have some good deals there, but you may be better off going into somewhere local and having a listen, as they may be able to put together a package for you at your budget that's not shown on the website.
Jano, what do you advise mate from my posts above? Thanks.
