Hi Guys hope I could share some problems I'm having with a new build I'm watercooling the following :
3930 intel CPU and chipset with ek blocks running through a XSPC EX280 rad on a seperate loop and on the other loop 2 titans in SLI running through a XSPC 560 rad.Fans are Akasa Apache.In a Silverstone TJ11
All at stock the system seem very hot when I'm playing say Battlefield 4 to be honest I feel like im using an intel stock cooler its so hot I've been using the Fans all maxed out and am getting tese Temps :
image upload no size limit
Where is the air exhausting on that? Are you running it without the side panel? Your GPU temps do seem a little on the high side, but not too much.
