For anyone who may have been concerned about the recent HeartBleed bug which has been in the media, OcUK has not and wouldn't have been able to be affected as we were not running a vunerable version of OpenSSL.
Just a suggestion, is it possible for the login screen on the shop site to have tab-able fields so that 'email address' is the first tab-able field and password the second. This would then be consistent with the default behavior of KeePass. Currently it doesn't seem to be possible to tab between fields which doesn't suit Auto-Type feature of KeePass.
I gather the bug was introduced in a new version of open SSL released a couple of years ago. So is OCUK ok because of an "it ain't broke so don't fix it" approach to their website or because they don't bother to install updates!
Agreed. While this problem may have been more widespread and publicised than most there are security holes found in systems every day - I'd rather sites didn't spam me with what isn't affecting me!
Or they don't use SSL for their secure connections. Or they use SSL but don't use HeartBeat. Or many other answers that result in not affected. Given the wording in the OP I assume one of these two though.
