Yet another spec me thread...!
10 Jul 2010
It's been a while since I've upgraded and my current PC cost me about £330 for the motherboard, CPU, RAM and cooler.
I currently have the following:
  • Asus P5Q Pro motherboard
  • Intel E8400
  • 2 x 2GB DDR2
  • GTX 660
I must confess that I've not overclocked the above for any length of time - only once to see how far the CPU would go and I think it went to about 4GHz. Being honest, I rarely have the need for that amount of power unless I want to quickly encode the (rare) video.
With me using virtual machine, I finding myself wanting more RAM. 8GB would make things a lot more comfortable, but I'm thinking that 16GB would future-proof me for a good while to come. I could spend about £30 to get another 4GB of RAM, but I'm wondering if I'll just be sending good money after bad.
Being close to a year old, the graphic card is more than adequate for my needs. I do plan on buying an SSD drive in the future, along with a harddrive for storage.
My main concern is power consumption. Right now my power meter says the system is pulling around 80w at the plug. I don't expect this to get any higher with a new system; quite the opposite. I expect there to be a drop - not big, but to perhaps about 65w or better. Quad-core processor would be nice, but I'm concerned it will negatively affect the power consumption.
I'd like the new motherboard to be of an Asus brand, with support for USB 3 and onboard gigabit network. A PCI slot would also be handy, to support my soundcard.
I'm going to set my budget at a maximum of £350 and take it from there. From that budget, I'm looking for a motherboard, CPU, RAM and perhaps a cooler.
Let the speccing commence! :cool:
Here you go:
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £161.99
1 x Asus Z87M-PLUS Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £94.99
2 x Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/8X) £45.95 (£91.90)
Total : £348.88 (includes shipping : ).
Sorry, no cooler :p 16GB of 2400Mhz RAM for £90 is a great deal!! I got the 4670K instead of the 4670 because it was £3 more and you might change your mind about overclocking. The mobo says this:
"USB
- Intel® Z87 Express Chipset - supports ASUS USB 3.0 Boost
- 2 x USB 3.0/2.0 ports at mid-board for front panel support
- 4 x USB 3.0/2.0 ports at rear panel (blue)
- 8 x USB 2.0/1.1 ports (6 ports at mid-board, 2 ports at rear panel)"
"LAN
- Realtek® 8111GR Gigabit LAN controller"
So it meets your requirements
Here you go:
YOUR BASKET
"USB
"LAN
No PCI slot. :( :D
YOUR BASKET
1 x Asus Z87-A Intel Z87 (Socket 1150) DDR3 ATX Motherboard £106.99
Total : £106.99 (includes shipping : ).
No PCI slot. :( :D
YOUR BASKET
Damn! I failed :(
It has them but not x16, wouldn't it work?
"Expansion Slots
- 1 x PCI Express 3.0/2.0 x16 slot [yellow] (at x16 mode)
- 1 x PCI Express 2.0 x16 slot [dark brown] (run at x4 mode, compatible with PCIe x1 and x4 devices)
- 2 x PCI Express 2.0 x1 slots
- * The PCIe x16_2 slot shares bandwidth with PCIe x1_2 slot. The default setting is x2 mode. Go to the BIOS setup to change the settings.
Damn! I failed :(
"Expansion Slots
They are all PCIE slots, the OP's sound card requires a PCI slot.
So I'm right? The first mobo would work, right?
No. The motherboard you linked has PCI-E slots only..no straight PCI slots. The 2 aren't the same at all.
No, because it only has PCIE slots not PCI.
Z87M-PLUS
1 x PCIe 3.0/2.0 x16 (x16 mode, yellow)
1 x PCIe 2.0 x16 (x4 mode, dark brown) *1
2 x PCIe 2.0 x1
Asus Z87-A
2 x PCI Express 3.0/2.0 x16 slots (single at x16 or dual at x8/x8 mode)
1 x PCI Express 2.0 x16 slot (max. at x2 mode, compatible with PCIe x1 and x2 devices)
2 x PCI slots
