Looking for a high airflow white case
15 Feb 2011
Hello,
I've been looking for a white case for the last few days but i have a few requirements.
-Needs to be less then 50CM Deep and 51CM Tall, Width can be upto 28CM
-Would like to fit a 240/280MM Radiator on the top.
-Need 2x 240mm Intake fans
-Would like either side or bottom intake fans too.
Only one that meets most of my requirements is Thermaltake Chaser A31 Snow Edition from what i can see but i'm not that impressed with the style of the case.
The corsair 300R looks perfect but only comes in black, Would rather white but there are very limited white cases.
Budget isn't really an issue, Can spend around £150
Thanks
Yeah i love that case, Just wish it had better ventilation. My PC is almost enclosed so i need good airflow. Them tiny little vents just wouldn't work i don't think.
Corsair 600T white version, you can get it for under your budget if you look around, its a smart case with good air flow.
Sorry its probably bigger than the size requirements you posted.
Yeah, again i love the look of this case but slightly too big :(
@stulid: the AIR450 is too wide
I think i'm just going to have to get a black case, 450D seems perfect, Just wish it was white.
if ya really want a white case bad, get the 450d, take it to a professional spray shop and get it spray painted glossy white. It'll probably cost less than you think, maybe under £60, and it will be unique to you.
wow that does look good. I'm guessing not all garages will be willing to do it though. Will have to give a couple a ring.
