Is crossfire working on titanfall ?
just found one maxxes it at my refresh rate with power to spare but frame times are stuck at 12.5ms which feels poo :confused:
No SLI optimisations either. Heavy VRAM usage and poor optimisations are a shame for this game that is great fun.
Hows the performance, scaling and smoothness?
I think crossfire has been working since 14.3 in Titanfall.
Working very good, but to get 120fps you need to enable triple buffer and for some reason they locks the frame rate to mouse also. Strange choice
So if frame rate drops you feel it very bad, the good news running on single gpu @120fps frame rate does drop now with crossfire it don't so the mouse Lagg/fps drop is gone.
Still a poor ggame though, it's not very enjoyable to easy.
Good to hear. Not my cup of tea either and it has no in game benchmark so definitely not for me. :p
30GB of Audio.
Seriously, alarm bells should have been ringing there. (Albeit in extreme uncompressed clarity that only 0.0001% of audiophiles would have chance of hearing.)
30GB of Audio.
This isn't the reason for this uncompressed audio. They have uncompressed the audio to help low end hardware play the game better. Compressed audio is meant to be a performance killer on low end cpu, having the audio already uncompressed should help performance very much.
How much I have no idea.
30GB of Audio.
Yer, huge game download and most of it was audio. I like the game for a quick blast but could do with better SLI usage (2nd GPU is only at 15% usage roughly).
If the game fully used both GPU's, I could comfortably run full settings at 4K.
i get the same usage in crossfire, really poor game that way although to be fair i can run it on a single card with only about 85% usage everything maxed out.
thief is pretty much the same even on 14.4 as well
Have you tried the new drivers from AMD (14.4)? They fix Crossfire apparently :)
