Mattress of amazon, good or bad idea?
If you've tried the mattress and you're happy, then sure. Go for it.
If you're just buying one because of the "scale" then I wouldn't as it might not suit you. It's not just a scale, which is hardness, it's all about the amount of springs, if there's any springs at all, is it memory foam etc etc etc.
Find the mattress you want in a shop, then buy it for -25% online.
This. We recently went matress shopping and were tempted to do the same thing, but the difference between matresses on the same scale is huge.
From what I've heard it's best not to go for memory foam mattresses unless you're paying top dollar.
Why? Laying on a mattress for 5 minutes tells you precisely nothing that the specs won't already.
Specs won't tell you how it feels, how hard the springs are, how bumpy it is, and the give in memory foam. The same specs will also vary between manufacturers. Specs won't give you advice either. You'd be a fool to just go by specs but if comfort doesn't matter to you then why not....
Rubbish.
They all feel different. I'd never buy a mattress without laying on it first. You're going to be spending 7+ hours on it a night, I'd want to make damn sure it was comfortable.
Rubbish.
Hogwash. If that was true we wouldn't benchmark pc components would we?
Mattresses aren't about spec, they're about preference for different tasks and body types.
Your points are still completely moot given you're suggesting a 5 minute lay down in the middle of a shop to ascertain all of that information.
However the guys I linked to offer a 30-day no question/quibble guarantee so you can actually use it and return it. No shop will do that.
