I've just replaced my 700W OCZ power supply with a Corsair RM1000 which I picked up from the MM. That's the only thing that has been changed in my system recently.
Previously, when I would shut down my PC, the lights on my keyboard and mouse would remain on and this seemed normal. The led on the front of the fan controller would also remain lit. I've installed the new power supply and it seems to be working great however, after shutting down the system, all my case fans (6 of them) remain lit although they are quite dim. They are not spinning, the system has definitely shut down but the leds are still on and this seems a bit odd. Can this damage the fans? Is it normal??
I am going to try a different connector on the PSU and then a different cable. Anyone had this before?
As I said, the PSU seems to be working just fine. Just wondering if the above is something I should be concerned about.
