760W Enough for 780 SLi?
Running a single 780 w/ 4820K - with the CPU at 4.4GHz and the GPU at 1267MHz it hits a tiny bit over 400watt in BF4, running eve online at the moment its barely hitting 200watt.
If you were running a i7 w/ a mild OC and 2x 780 at stock probably see about ~590watt peak draw in BF4 (most games will be less).
The AX 760 should be able to handle it easily.
Will the age of a psu have much of an effect on sli 780's? IM gonna add a second card soon, psu is a first gen corsair HX 850w. Its at least 5 years old and has ran several highly clocked cpu's and sli'd gpu's in that time. Most recent beinng sli gtx 670's with the cpu in sig. Cards would be ran at stock for games and likely with a mild stock volt oc for a few benches.
