Just put the OEM choice on and be done with it?
[TW]Fox;24085485 said:The OEM choice for his car is probably the awful Bridgestone Potenza RE050 RFT's. Why would he want to put those on? Not only do they cost over a thousand quid for a set, they are also fairly terrible tyres which ruin the ride and handling of his car![]()
[TW]Fox;24085025 said:The CS3 is what, 8ish years old now.
What do they fit when you do not spec RFTs, or is that not an 'option' ?
Just to revive an old thread. I thought I would share what a woeful experience the CS3s were on the front of the E60. A horrible tyre which wore rapidly on the outside edge and caused a step to appear to the next central block section. This has produced road noise akin to wheel bearings (although my rear bearings were shot too, and have been done).
I find it odd that these tyres have only managed a year, and probably 20k miles, but there you go.
So, I'll be on the hunt for some MPSS for the fronts too.
Never had this trouble with either the CS3s or CS5s on the Leon.
I've moved to F1A2s on the Focus though.
