I've got a K5 and love it, very powerful, but majorly overkill.
Don't forget to check out the karcher outlet if you're happy with a damaged box/refurb unit, some good savings to be had occasionally.
Snow foam?
put a half inch layer of thick foam on you car and removes dirt and traffic film in about 5-10 mins without the use of a sponge.
just rinse off after the 5-10 mins.
best way to clean a car imo, gets into the places that you can't with a sponge or brush.
Most vastly overhyped car cleaning product on the net, a dirty car will remain a dirty car regardless of how much snow foam you spray at it.
This is what I use with my K3:-Where do I get decent snow foam? And how do I apply it?
Decent snow foam will lift off most winter dirt without having to do much else!
I'd rather not blast the dirt off myself.Yeah but so does a high pressure rinse with a pressure washer.![]()
