Here's a vid for an idea:-
To be honest his foam looks weak, but it gives you an idea.
Have a look around cleanyourcar.co.uk.
Yeah but so does a high pressure rinse with a pressure washer.![]()
I'd rather not blast the dirt off myself.
Because it has more uses than merely blasting dirt off car paintwork?Why not lol. What is the point in buying a pressure washer if your not going to use it? Stick to the hose.![]()
Snow foam is just a high foaming TFR. I use it on customers cars to give them a bit of a show. I buy mine from autobrite which come in different flavours such as banana, blueberry etc.
As for Karchers, you get what you pay for. Nilfisk are good, but you try getting them serviced. Go for a K5 and above as they use ceramic components, not plastic, which is where most will fail. For reference, I have a Karcher which was built in 1994 that gets used heavily.
I'm still none the wiser about whether snow foam is a gimmick or the best thing since sliced bread.
If you have to leave it 5-10 mins and then still have to use a mitt anyway, isn't it quicker to just use a mitt and bucket method from the off?
Most vastly overhyped car cleaning product on the net, a dirty car will remain a dirty car regardless of how much snow foam you spray at it.
Will my Karcher K2 be powerful enough to do a good job with the snow foam attachments?
