SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £139.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
- Product Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=340
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Modular Cable Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £139.99 inc VAT.
ORDER NOW
_____
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail @ £227.99 inc VAT
Intel's 4th gen processor codename: Haswell offers superior performance over the previous generation Ivybridge by up to 10% clock for clock. This astounding performance boost results in performance improvements in multi-tasking, encoding, gaming and multithreaded applications. Intel's 4th generation processor has improved PCI-Lane 3.0 bandwidth which helps further boost performance of latest generation 3 graphics cards for the ultimate gaming experience.
For overclocking enthusiasts, Intel's 4th gen CPU has improved memory overclocking support, with up to and beyond 3000MHz possible with the very best memory kits. Memory bandwidth is critically important to Haswell compared to previous generations. High frequency memory performance significantly improves encoding, gaming and benchmarking tasks.
The biggest leap in Intel's Haswell processor is the onboard graphics which is now up to 2.6x faster than previous HD4000 found in the Ivybridge CPU. What this means is these latest processors can actually play the latest games in HD with low/medium settings applied. Of course if you want to experience True HD gaming at maximum details then a dedicated graphics card is still a must.
There are two words in your vocabulary that should never meet—Game and Over. You love playing, and you love winning, so you demand unmatched performance, the ability to customize your rig, and features that put you in control of the action. With Intel® technology, you step into a heart-pounding experience. Pick up your weapon, challenge your friends, and experience gaming at its best—because the only thing more amazing than Intel® technology is what you’ll do with it.
As a creative force and a professional, you must continually balance your vision with the deadlines of the real world. Intel® technology helps you keep up with your creativity with unmatched and customizable performance, and features that give you full control to optimize your workflow and maximize your productivity. So keep imagining, keep creating, and take your inspiration to the limit—because the only thing more amazing than Intel® technology is what you’ll do with it.
Features:-
- Upto 10% performance increase over Ivybridge on CPU performance
- Upto 2.6x performance increase on 3D Graphics (onboard GPU) with DX11.1 Support & OCL1.2
- Better OC Flexibility with memory timings and speeds
- 4k and Collage Display support
- Intel Password Guard for SBA and improved protection against data theft
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Integrated HD 4600 Graphics
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr Warranty
Only £227.99 inc VAT.
ORDER NOW
Features
Specification:-
- Type ATX
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
_____
Features:-
Specification:-
- Cores: 4
- Threads: 8
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
