Sell 690 and get 780 sli?
23 Mar 2012
Hey guys.
I'm thinking of making the leap to 1440p gaming and i've heard the 690 doesn't do so well due to it only have 2gb of Ram.
If i sell it and get 2 780's in sli will that give me good performance at 1440p resolution?
Also i'm confused which 780's to get. Reference or non reference? I've heard non reference cards dump hot air back into the case whereas reference ones don't. Is that true?
Cheers
Ish
Sli 780 would do quite well.
And then as long as it's a good cooler on it it shouldbe fine. Check the clearance section as there were a few of them for £329
In simple terms... Yeah, a lot of them (if not all) do.
Some have a bit of a rear vent, but there's so much space around the sides of the heatsinks and so much air being blasted on to the card that a lot of it goes out the sides.
But that's where your case fans come in. IIRC, aside from looking wicked, your 600T can fit 4x 120mm fans on the side panel, has 200mm front intake and top exhaust (the latter of which can accomodate 2x 120s instead), plus another 120mm rear exhaust?
That's pretty hefty on the positive pressure side...
Heat does not rise, as many people claim, but hot air does. Cold air displaces warmer air upward and most of your fans are pushing cold air in, which will force the warm air up and out. Not really very scientific an explanation, but that's basically how it works.
So in short, if your current cooling is good then it shouldn't be a problem.
As for the card - Generally non-reference ones have better coolers and more features, like overclocking ability... generally. There are always exceptions.
A pair of 780s in SLI will be utterly awesome, possibly even considerable overkill, unless you're planning on trying for an overclocking record.
I only have 1080p myself, but most enthusiasts I know personally with 1440 still only have a single card and are chuffed to bits as far as general gaming goes. One has a single 780Ti, which is the next level up and pretty much top of the board as far as Nvidia graphics cards go.
It all depends what you want to do with this build and how much you want to spend.
Another that was recommended to me was the EVGA GeForce GTX780 Classified.
I personally chose the MSI GTX780 Lightning, which is astounding anyway and overclocks very well.
You may also wish to consider the AMD range of R9-280s and R9-290s, both of which come in standard and X versions, also top-end cards.
Keep the GTX 690, get a 1440p monitor and give it a go.
I use my GTX 690s @1600p and don't have a problem.
There are games that are coming on the market (when maxed) that will get close to the 2gb vram on the 690 but you run out of GPU grunt before you run out of vram so it is not a problem.
What I mean by the above using Crysis 3 as an example is if you max it at 1600p and use a couple of Titan's, 780ti's, or 290Xs you will get around 50fps and will need to reduce the settings to get a constant 60fps.
On the other hand if you want a faster system then upgrading to a couple of GTX 780s will give you a fps improvement but not as big an improvement as some people would think.
2 780 Ti's here. Absolutely awesome, and I currently game at 2560 x 1080. Quite a few titles out there push them in SLI to their upper limits already. Crysis 3 maxed, Ass creed 4 maxed, and Skyrim ENB modded to name a few. So don't worry about overkill!
Getting the Ti versions was probably a moment of madness really, as 780s would do the job. But it's nice to have the best for once, and they do look cool. I got reference designed cooler ones by the way, inno3d when they were on offer at £499 each.
I've set a fan curve that keeps them at 80 degrees max whilst both boosting to 1006 with no overclocking. Non ref coolers will run cooler, but for SLI as you say some people think having 2 ref collets is better.
keep the 690 and wait for the next gen. even though I have 2 x 680's wont be going 780SLI no game is struggling @ 2560 x 1440 80Hz @ max settings Have to say im loving TITANFALL at the moment
Have u gave your clock a bump on the memory and core?
I have 4 extra 120mm side case fans...the bottom 2 sucking in air for the gpu and the top 2 as exhaust fans to blow hot air out...its made a difference to the gpu temps about 8-10c lower.
I have tried oc my card but cant get more than 65+ on the core and 85+ in the memory...guess mine is a bad overclocker...so I keep it stock.
It's still an impressive card and I do play some games at 2560 x 1440p via downsampling and get good fps...but I guess thats not the same as having a native 1440p monitor?
I guess I have that upgrade itch.
Why is this? I thought a few years ago Sli of two cards produced close 80% more performance than one, yet I agree, some of the benchmarks I've seen of the 780 ti sli seem to be around only 30% better than 1 card (from what I remember). Any particular reason ?
I would get the 1440p screen before upgrading the gpu. The 690 is a superb card and I would not let the V-Ram police scare you too much. I think you will be pleasantly surprised how well the 690 handles 1440p even with only 2GB.
Could be several reasons
1. The drivers are rubbish, yes NVidia have their turkeys.:D
2. The game support is not there.
3. There is a serious CPU bottleneck
4. There are probably other reasons too
A good example of 1 and 3 combined was the Sleeping Dogs bench, with 4 Titan's the best I could do was about 155 fps, then NV released the 337.5 drivers and I was getting about 216fps.
With a fast GPU setup I find it a lot easier to use very high settings on the cards to keep the fps down and also get the max scaling by avoiding CPU bottlenecks.
+1
Get screen try if you find issues then worry about upgrading imo
I totally agree, I have effectively 1.5 gig vram on my 590 gtx's and I'm 2560x1600 and it still rocks. Screen would definately be the smarter buy atm
