- 30 Jan 2014
http://www.sendspace.com/file/jmc75m
is the link for my card. do i need to save both bios off both cards???
If the cards are identical and were bought at the same time, no. I'll take a look.
im assuming that if i bugger this up its just a case of changing the switch on the gpu from 1 to 2 and it will have the card back working again.
also do i need to do both cards at same time or should i just do 1 restart windows make sure everything is ok then do next card
all give it a go once i can get my usb stick back from the weans.
also i have a prog called vbe7 is that what you use to look at and change settings on the bios??? if so the card is locked to a max of 1200 on the voltage
good stuff also can i use atiwinflash to flash the bios????
this was the one i was meaning
http://www.overclock.net/t/1353325/tutorial-atiwinflash-how-to-flash-the-bios-of-your-ati-cards
one last thing does it matter what bios is used as long as both cards are on the same bios
both cards now flashed and showing the limit as 1300 and power limit 200-300
