- 30 Jan 2014
it does now in hwinfo it shows a max voltage of 1.300v just managed to do a full run of valley at 1200 clocks that i never managed before
200-300?
Use gpu-z to see if it actually shows the voltage increasing under load.
with the limit now set at 1300v does that mean the card will never go above 1300???
so if i set the power limit % at 20 does that mean it will boost over 1.3v or is it locked in so it cant go any higher than that???
1.3v is your stock voltage and now your maximum. You should always use +20% power limit as well.
Now see how high those clocks can go
Btw, good work Matt.
