You've done the research, you've seen it is a common issue, and you aren't saying you can't get to the volume you want so Im not sure what you want us to say? no offense, but this is perplexing me.
Have you changed the BIOS settings so the soundcard is default?
Yes I have changed the bios settings sure.
And in reference to your comment about what I expect you to say... no offence but I don't think you read my original posts.
1st Post - I stated the volume is lower and what gives with this? (this was my question).
And then in your first post you ask me yes its lower whats my question?
2nd Post - I state my question again, is this normal for this card? Have I done something wrong?
(To which there was no answer - so off I went to do some research)
3rd Post - I confirmed this card has issues concerning volume as per the link above.
4th Post - was a response to a user and a comment about the front panel and my assumptions about these Soundcards and the expectations of something like this, perhaps I misunderstood when I first purchased this.
Im not expecting you to say anything now because I have recognised the problem and I shall be RMAing the card back to the supplier. Thanks.
I had the opposite problem that you have, not matter what the volume was the card turned it up. After installing modded drivers that problem went away, I think its time asus get their drivers right.
Try this out -
http://maxedtech.com/asus-xonar-unified-drivers/
Thanks for your suggestion bud, but I am dubious about using 3rd party drivers and all that. Its a bit poor on the part of Asus when users have to use modded drivers etc. In the end I think Im going to RMA this card for now.
have you got the right gain setting for your headphones?
When you've got headphones plugged in or selected in the driver panel, an extra button should appear next to the speaker test button. It should allow three gain modes, VOIP, Pro Gaming and Exciter, which basically equate to less than 32ohms, 32ohms to 64 ohms and over 64 ohms. If your headphones are high impedance and the lowest gain is selected then the volume will be too quiet and if you have low impedance headphones and the gain is set high then you'll get the opposite. Just pick the one that suits your phones the best.
Thanks yes I did play with this and increasing the impedance to the Exciter setting (over 64ohms) did work but again its nowhere near as the levels I had with the onboard audio.
Thanks to all for your help folks.
