- 7 Sep 2012
- Lancashire, England
Hi all,
I'm hoping someone here can help me with a slightly irritating issue! I upgraded a friends OS from Windows XP to Windows 7 64-bit and also added an extra 2GB RAM (making the total 4GB). The system BIOS detects all 4GB perfectly fine and Windows 7 can see 4GB, but it shows up as only 2.75GB useable . I've tried checking/unchecking the max mem option in msconfig with no luck. I also can't see any memory remapping options in the BIOS setup and the PC has a dedicated GPU.
It's an old Compaq SR1000 series PC (SR1639UK) with the following specs:
AMD Athlon 64 X2 4200+ cpu (2.2ghZ)
4GB PC3200 DDR RAM (4x1GB)
Dedicated 512MB Geforce 210 GPU (PCIe)
250GB SATA HDD
DVD/RW optical drive (IDE)
Windows 7 Home Premium 64-bit
The resource meter shows 1282MB is apparently reserved for hardware which seems a bit strange!
Any help is much appreciated! Cheers
250GB SATA HDD
