Unigine Heaven Benchmark 4.0
FPS: 103.8
Score:2614
Min FPS:30.3
Max FPS:212.8
System Platform:Windows 7 (build 7601, Service Pack 1) 64bit
CPU model: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (3292MHz) x4
GPU model: Intel(R) HD Graphics 3000 9.17.10.3347/AMD Radeon R9 200 Series 14.100.0.0/AMD Radeon R9 200 Series 14.100.0.0 (4095MB) x1
Settings Render:
Direct3D11
Mode:1920x1080 8xAA fullscreen
Preset Custom
Quality Ultra
Tessellation:Extreme
Powered by UNIGINE Engine
Unigine Corp. © 2005-2013
3DMark 11 P15495 with AMD Radeon R9 295X2(2x) and Intel Core i5-2500K Processor
3DMark Fire Strike 13540
No idea if these numbers are any good but the CPU will be getting updated later in the year which should improve things.
Here is a run done with two single 290Xs @1018/1250 the same clocks as yours.
http://www.3dmark.com/3dm/2954680
If you compare the graphics scores there is not a lot in it, so yes your card is working fine.
